It is currently Fri Jul 25, 2025 1:09 am
PostPosted: Wed Jun 13, 2007 2:35 pm
I have plans on the way but I was wondering if anyone here could let me know the soundhole diameter on the OLF OM. See I thought I was going to wing the size/shape/bracing pattern with this first build, but I decided to go with something more tried-and-true. I already did the rosette and cut out the soundhole, so I am hoping that mine will match up to that.
Thanks!
Christian
Christian
PostPosted: Wed Jun 13, 2007 3:05 pm
First name: Blain
City: Leander
I could tell you for a couple of Bending forms and a mold. (Just kidding)
I also recently ordered the OLF plans and haven't received them yet, but I do have the plans from the book that I have (not sure if it's standard though), and it says the soundhole is 100mm or 3-15/16in (I guess basically 4 inches).
Someone else who's already familar with the OM could probably verify that or tell you otherwise.
Good luck with your build!
Blain
http://www.ullrichguitar.com
PostPosted: Wed Jun 13, 2007 3:07 pm
First name: Blain
City: Leander
Oops. Looks like Hesh just did...
Blain
PostPosted: Wed Jun 13, 2007 3:56 pm
[QUOTE=blain1976]I could tell you for a couple of Bending forms and a mold. (Just kidding)
Sry!
Ok, lets just hypothetically say that my soundhole ID is 3.7 or so (without the soundhole binding it would be more like 3.9) .... is this going to make a big difference in the sound/volume?? Aesthetically it looks fine... I think anyway.
Christian
PostPosted: Wed Jun 13, 2007 4:17 pm
Those sides look like some nice birch, Christian. A bit thick, though!
PostPosted: Wed Jun 13, 2007 4:35 pm
Nice one Pat... Well even though it's my first, I'm not afraid to think outside the box. At least they'll be stiff.
Christian
PostPosted: Wed Jun 13, 2007 5:25 pm
A smaller soundhole will make a difference, but whether or not you will actually notice it is questionable. There will definitely be a little less volume. Yours is so close to the 4" required that I dont think I would sweat it if it were me.
PostPosted: Wed Jun 13, 2007 8:25 pm
I use 100mm for OMs (and just about everything else) say 4" in old fashioned measurements.
Yours at 3.7" is on the face of it only 0.3" smaller. However this is a larger proportion of the area than the 0.3 would seem at first sight, as this is taken from the outside edge so would represent the difference in area of a circle 3.7" and 4". The difference is more than 1.8sq" or nearly 20% bigger. that is not inconsiderable.
My solution would be to add a soundport in the upper bout, this is easily done and will offset any reduction in soundhole size (they add a great quality to the perceived sound anyway.)
Something like this:
PostPosted: Thu Jun 14, 2007 12:12 am
Well said and good recommendation Colin
PostPosted: Thu Jun 14, 2007 4:37 am
OK, I forget what affect soundhole changes make.
Can someone help the boy?
Generally speaking, does a larger soundhole tend to make the sound more harsh, with more highs and less bass and a smaller sound-hole add some bass and cut some of the highs?
PostPosted: Thu Jun 14, 2007 8:08 am
[QUOTE=SteveS] OK, I forget what affect soundhole changes make.
Generally speaking, does a larger soundhole tend to make the sound more harsh, with more highs and less bass and a smaller sound-hole add some bass and cut some of the highs? [/QUOTE]
The general "rule of thumb" is that a smaller soundhole favors the bass, and a larger soundhole favors the treble. If you add a side port, it's likely to favor the treble in either case. Alan Carruth could tell you why.
PostPosted: Thu Jun 14, 2007 8:10 am
Ok all,
Thanks for the suggestions, now I have some options to weigh before making a decision. I like the soundport idea because I already had some visions of doing this. I am not sure if I will scrap the binding yet to open it up... I think it looks purdy
I'll be moving forward soon, so I will let you all know. Thanks!!!
Christian
PostPosted: Thu Jun 14, 2007 9:02 am
You can cut a soundport at any time during the construction. Some cut them before bending some, after bending when the sides have had the head and tail blocks glued in place. I do mine after the back is on but before the top.
That said I have successfully added a soundport as a retro-fit to some of my guitars, no need to take them apart.
PostPosted: Thu Jun 14, 2007 1:32 pm
In my limited experience, I think a smaller soundhole leads to a tighter more focused sound. I am building OMs with 3.75" soundholes.
David White, Toronto
